G23 oil cooler
G23 oil cooler
So my h22 block had an oil cooler sandwiched between block and filter. I wish to utilize this on F23 block bcuz oil cooler. There's no coolant port on back of F block to accommodate. is it a good idea to Y off heater line? Should be post-cylinder coolant and I've accounted for the return to rad
Re: G23 oil cooler
Oh, and what do you big block guys do for block scavenging/PVC? Not sure where separator box would go, Ds have them on back of block.
Re: G23 oil cooler
Why not run a sandwich plate (the kind with the thermo-pill valve inside, not the cheap ones off ebay) and route 1/2" trans cooler hose to a universal oil cooler in front of the radiator?
Re: G23 oil cooler
G23 is always cool.
x2 on this
Re: G23 oil cooler
HiProfile
07-03-2005 07:13 AM
