H22a1 Swap.
Re: H22a1 Swap. (WAFFLES)
like noting you would just have to do the same thing to swap a gsr in a hatch. Except you dont have to worry about axles. Or you could just get a h22a head and swap it on and abasiclly its the same as ls/vtec.
1 Post
Re: H22a1 Swap. (Blurple92si)
You'd have to get a n H22 (VTEC) ecu and add a wire for VTEC (from the VTEC solonoid to your ecu). I'm not sure if there is anything else that needs to be done.
I suggest check out prelude forum.
wickedxboi
04-15-2003 08:28 AM
