VTEC wiring help...
Old Oct 16, 2001 | 05:47 PM
Tomakit's Avatar
Default VTEC wiring help...
I've got a 95 LS-SE running a 98 gsr motor all on a P72 ecu. Now, the car didn't originally come with vtec, so i know that i have to run 4 wires to the ecu. but which ones?
Tom
Old Oct 16, 2001 | 07:29 PM
rainforest's Avatar
Default Re: VTEC wiring help... (Tomakit)
knock sensor, vtec selonoid, vtec oil pressure sensor, and secondary o2 sensor. plus since its a gsr a secondary intake selonoid.
Old Oct 17, 2001 | 07:07 PM
cbrman's Avatar
Default Re: VTEC wiring help... (rainforest)
Rainforest, you seem to be pretty knowlegable about hondas, what all would I have to add if I am installing a d16y8 sohc vtec into a 91 crx? I have the complete wiring harness all the way to the ecu, obviously i don't want to use the obd2. Would it be easier to transplant sensors from non obd to the y8 and get a zdyne, or should i make a harness and use the y8 wiring? I am near the tarpon springs area if you would like to help me
ifIexplode
Mar 3, 2007 04:28 PM
sobe
Apr 17, 2005 04:38 PM
Slimm-rw-
Jun 13, 2004 08:24 PM
powerslide360
May 20, 2004 01:21 PM
pkripper
Aug 11, 2001 04:07 PM
