Difference between B20b And B18b?????
Old Oct 4, 2001 | 12:59 PM
MXPX's Avatar
New User
Default Difference between B20b And B18b?????
self explanitory!
Old Oct 4, 2001 | 01:42 PM
WAFFLES's Avatar
Default Re: Difference between B20b And B18b????? (SlooowEG)
Bore diameter. that's it.
Old Oct 4, 2001 | 07:15 PM
rainforest's Avatar
Default Re: Difference between B20b And B18b????? (WAFFLES)
the horrible intake manifold and exhaust manifold design on the b20. Also the location of the pcv .
Old Oct 5, 2001 | 04:52 AM
mannyman's Avatar
El Veterano de Sur Califas
Default Re: Difference between B20b And B18b????? (rainforest)
and dont forget about the stronger siameese(spelling??) cylinder walls, and plus they are way thicker than the b18's. And the b20 has a spot for a knock sensor, b18b does'nt. i think thats it, except that ones a 2.0 and the other a 1.8
Old Oct 6, 2001 | 01:24 AM
GZR4DR's Avatar
Default Re: Difference between B20b And B18b????? (mannyman)
You forgot that the B20B or B20Z also has the higher output oilpump that is the same as the GSR and ITR. Also the intake manifold on some JDM B20's have the exact same intake manifold as the B18B. Its from the SMX in Japan.
Old Oct 6, 2001 | 04:38 AM
mannyman's Avatar
Default Re: Difference between B20b And B18b????? (GZR4DR)
yup yup, forgot about that one
johndilt
May 7, 2007 04:24 PM
johndilt
Apr 3, 2007 05:03 PM
johndilt
Mar 19, 2007 06:52 PM
93CharcoalHatch
Jan 9, 2006 04:07 PM
CRXLST
Jan 7, 2004 11:10 PM
