need help with overheating problem
ok my friggin car is over heating 92cx with first gen b16a i replaced the thermostat the waterpump and the fan is working, but sometimes it still overheats, im beginning to think it's some major thing now anyone know whats what? oh yah i think my thermostat sensor is shot i have to hardwire the fan to go on, anyone which sensor i need to replace it
I have a 95 hatch with a LS/ Turbo and something I did to prevent it from overheating was bought a radiator for a DOHC VTEC DelSol. It's the same length, but it's a duel core instead of the single core that comes in our. It bolts right in and you can get them brand new for a little over 115$ from www.radiator.com
[Modified by jbsadler, 4:40 AM 10/4/2001]
Did you replace the head gasket? Could be a blown headgasket or a bad temperature sensor. These should of been replaced prior to installation.
Check for leaks make sure nothing is cracked or any of the coolant hoses are split. If there is a leak make sure its not the thermostat housing its real flimsy.
moldy
Aug 8, 2006 03:59 AM
