Injector questions, just need verification.
New User
Okay, I have an OBDII engine in an OBDI car and I use an OBDI computer. In laymans terms: 93 hatch with 00 gsr engine and 95 gsr ecu. Do I need to get OBD I injectors or are the injectors that came with the engine which are OBDII fine? OBDII injectors will work using OBDI ecu's right? And vice versa? Either process works unless you use a pre OBD ecu right? Please verify!! THanx.
