help tranny swap
Old Sep 30, 2001 | 08:13 PM
PolosportZ81's Avatar
New User
Default help tranny swap
i have a 98 civic ex...i'm trying to do a auto to 5 speed conversion....does anyone kno exactly what parts i will need? thanks so much
Ben
Old Sep 30, 2001 | 08:45 PM
WykidEH's Avatar
Default Re: help tranny swap (PolosportZ81)
what's up, ok, you'll need shift limkage, man. trans., clutch m/c, clutch hard lines, clutch pedal set(clutch and brake are one unit), manual ECU, manual motor mouonts, clutch slave cylinder, short throw, manual console, Si gaugecluster, manual throttlecable, 3 quarts honda manual tranny fluid, manual flywheel, clutch set(of your choice) and pilot bearing. that should be all you need todo the swap into your '98 Civic EX and shift away. . . . .
Old Oct 1, 2001 | 08:26 AM
WykidEH's Avatar
Default Re: help tranny swap (WykidEG6)
ok
Old Oct 1, 2001 | 07:25 PM
PhucNguyen57's Avatar
I have no intention of trash talking, but you migh consider another option.Just keep saving your money and put in a B16, it is cheap, in my opinion easier than swaping the transmission. and the performance gains are far greater than doing a 5speed tranny.
Just a thought
Randal
Old Oct 2, 2001 | 06:04 AM
New User
Default Re: help tranny swap (PhucNguyen57)
no no i'm thinking of goin turbo after i do the swap instead of gettinga b 18b and doin a swap...thanks for replying tho
Ben
Old Oct 2, 2001 | 07:07 AM
clockworks's Avatar
put in a B16... the performance gains are far greater than doing a 5speed tranny.
I beg to differ, honda auto trannies suck my ****. If you have an auto, the best thing to do is swap in a manual. Use that as a starting point, then you can swap an engine.
MisterZJ
Apr 24, 2009 02:20 AM
Midori Green
13
Dec 6, 2006 04:56 PM
honda94civicturbo
11
Dec 23, 2004 09:18 AM
95'turbotegra
Nov 28, 2004 06:09 PM
AznInvasion
Sep 12, 2003 06:19 PM
