Car sputtering
Old Oct 17, 2001 | 06:41 PM
duo17e's Avatar
Default Car sputtering
I have a 1st gen. b16. Every time I floor the car it sputters whnever it hits vtec.I t doesnt matter what gear im in ,it does it from 1st - 5th . I've changed my plugs ,wires ,coil ,cap;n;rotor. The only thing i haven't changed is the whole distributer. Anyone had a simular problem? How did you solve it? Any info greatly appreciated!!
Old Oct 17, 2001 | 07:23 PM
FSTASNTZ's Avatar
Default Re: Car sputtering (duo17e)
What ECU, fuel pump, injectors and fuel pressure are you using? What are you using the regulate fuel pressure?
Jason
Old Oct 18, 2001 | 01:17 AM
duo17e's Avatar
Default Re: Car sputtering (FSTASNTZ)
I am using my stock pump, PR3 ecu ,B&M fuel pressure riser set at 41.The car is an 88 H/B. Thanks for the reply!!
Old Oct 18, 2001 | 07:01 AM
FSTASNTZ's Avatar
Do you have a fuel pressure gauge to monitor pressure in the system? It is possible that the stock pump you have cannot handle the demands of the B16.
Jason
Old Oct 18, 2001 | 08:02 AM
rainforest's Avatar
check your spark plug wires and the gap of your spark plugs if you still have a problem.
Old Oct 18, 2001 | 05:04 PM
duo17e's Avatar
What fuel pump should I try and is it a direct fit?
jdmdood333
14
Aug 27, 2012 12:02 PM
B16-CRX
Oct 4, 2010 04:32 PM
Mref813
Dec 31, 2009 04:43 PM
092eg6
Dec 11, 2009 01:36 PM
W0oT
Aug 21, 2002 06:33 AM
