Vtec problem
Old Oct 23, 2001 | 08:11 AM
vspec12's Avatar
New User
Default Vtec problem
Hi, I just recently changed the block on my Ls-vtec, and now the vtec dont wanna work. I hard wired it to a 11V pwr source to activate the soleniod and it still don't want to work, I also swap out soleniods. Does the soleniod need a certain amount of volts, cause it does click w/ the 11V. My next step I think is to check the pressure on the oil line, but does anybody know what it should be? Thanks for your help...
Old Oct 25, 2001 | 11:38 PM
I-VTECRX's Avatar
Default Re: Vtec problem (vspec12)
yah on normal driving its about 5psi but when vtec occurs it pumps 60psi
Old Oct 26, 2001 | 05:37 AM
vspec12's Avatar
New User
Default Re: Vtec problem (EF8hYbRid)
does the oil pressure reach 60 w/out the vtec, or does it go to 60 psi when the vtec hits?
Old Oct 26, 2001 | 10:01 AM
90accord1's Avatar
i beleive itll hit 55 without vtec comming ona nd its 12v source for vtec i think if that matters.
Old Oct 26, 2001 | 03:19 PM
Turbohatch's Avatar
New User
so you have vtec on the button. Vtec on the button only activates the solinod to poen up v-tec if your ecu is not Vtec you will not get the same fuel curves as a vtec ecu.
Old Oct 29, 2001 | 05:28 AM
vspec12's Avatar
New User
Default Re: Vtec problem (Turbohatch)
I have a b16 ecu, the thing is, Im still trying to figure out how to wire the oil pressure. till then I just wanted to check if the vtec worked by hooking it up to a switch. and it just don work, I also checked for that rubber ring under the middle journal, Im at a loss
Old Oct 29, 2001 | 07:06 AM
rainforest's Avatar
55 psi is when vyec opens. also I dont understand is the vtec oil press sensor not wire up. have you checked the oil press. its easy. It just plugs into the vtec selonoig and then bam. check any honda VTEC manuel and it will show you how to do it.
Old Oct 29, 2001 | 07:13 AM
vspec12's Avatar
New User
Default Re: Vtec problem (rainforest)
My oil pressure sensor is not up cause I have a ls harness, and I still havent figured out how to tap it, I heard there it needs to be tapped in two placess to work
Old Nov 1, 2001 | 11:43 AM
GEN2 HYBRID's Avatar
i had the same problem once when i switched my vtec oil supply line to a smaller size. everthing was working but the vtec wuld not turn on. when i switched back to the larger size everthing worked like it should. BaaaaaaAAAAAA!
try a larger line.
Old Nov 5, 2001 | 05:25 AM
vspec12's Avatar
New User
Default Re: Vtec problem (GEN2 HYBRID)
you know, I didn't change my oil line, but I did put another elbow fitting on the end of it, maybe the fitting is causing the trouble... thanks for your help
swizz977
10
May 25, 2011 08:15 PM
boosted k20
Jul 21, 2005 07:15 PM
DXDOHCVTEC
Jul 29, 2004 10:34 PM
CompressionFed
Mar 23, 2004 04:54 AM
b19coupe
Sep 3, 2003 07:02 PM
