B16 timing belt do not fit on ls/vtec setup????
New User
how come the timing belt dont fit. i have seen a lot of motor that do fit the b16 timing belt. i do understand that the ls block is longer than the b16?? what are you guys advise??
Banned
Re: B16 timing belt do not fit on ls/vtec setup???? (rainforest)
if you used an ls water pump you have to use an ls timing belt. To make the b16 belt fit you need to use a b16 water pump.
hybridb18
02-18-2004 07:40 PM
