Wiring a d16y8 Obd2 into a 91 crx si non-obd car Questions
Ok i purchased a 98 d16y8 motor for a swap into my crx. It came complete with the wiring all the way to the ecu. Should i swap all the sensors from the a6 motor (non-obd) onto the y8 motor (and get a harness converter to run a p28 ecu), or should I try to transplant the y8 and wiring harness into the crx(and get a harness to run a non obd2 ecu)? If I were to use the non-obd wiring harness, how many wires will i have to add, and which ones?
Thanks
Steven
Thanks
Steven
