Ls/vtec crx
Old Oct 7, 2001 | 01:14 PM
T.Werd's Avatar
New User
Default Ls/vtec crx
My current set up is a 91 Crx with a 91 Ls motor and tranny. I just bought a complete Gsr head with manifold and all the other stuff I need. My question is what do I need to do to my wiring to be able to run the Ls vtec? Could I just buy a V-AFC controller or will I need to witch over to the GSR ECU? If I need to switch over to the GSR ECU what is involved in the wiring? thanks for the help
Old Oct 7, 2001 | 10:13 PM
SiR831's Avatar
Default Re: Ls/vtec crx (10sec.civic)
Run 1st gen. JDM B16a ecu and convert your LS wiring to B16a
Old Oct 8, 2001 | 04:24 AM
CRX_VTEC's Avatar
Default Re: Ls/vtec crx (SiR831)
since you didnt mention the oil line .. I guess you must have that already covered.
Old Oct 8, 2001 | 08:10 AM
1.8EG-T's Avatar
Default Re: Ls/vtec crx (CRX_VTEC)
As said before you can use the pr3 or pw0, but you will have the problem with the dual runners on the gsr intake, unless you buy a skunk manifold or a similar one. If you use the pr3 you are also going to have to do another o2 sensor bung on the manifold. This is what I would do. Also when you get your ecu, make sure that it is a manual trans version and not an auto as performance will suffer.
Old Oct 8, 2001 | 08:26 AM
T.Werd's Avatar
New User
Default Re: Ls/vtec crx (hybridrex)
Is there any way to just wire in a VAFC into the Ls wiring and control the vtec and make the necesry fuel adjustments with it and thats all that I would have to do for Wiring. This is going to be a tightly budgeted car and I already have the Ls wired in and dont have connections to get b16a stuff like I can other b series stuff.
almostjdmeg
Dec 10, 2008 03:49 PM
92HB_HB
Jun 25, 2004 08:22 PM
C R X
Oct 11, 2003 10:37 AM
cbmlsvteg
Nov 11, 2002 05:25 PM
