question about a crx head swap
does anyone know what head and intake will bolt up to a crx block without having to change or do anything special to it? i am looking to just bolt on a new head and intake, with the wiring and ecu. what will fit? what will give me the most power out of the engine from the head?
Re: question about a crx head swap (crxplus)
the d16y8 head on the d16a8 block...with no mods... and the d16z6 head with little mods to the distro.. i believe it is drilling a new hole or something... i'm not too sure about the intake...
the mini-me swap ...i believe gives around 125-130hp... maybe someone who actually did this swap can give you more information... goodluck on your swap if you do try it!
Re: question about a crx head swap (gCboY)
yeah with the mini me you have to do a few things, such as get a vtec controler or rpm activator swich. 92-up fuel rail and regulator,92-95 ex/si head gasket,and sohc vtec timing belt.
as i lay dying
04-21-2004 05:48 PM
