Help! A/C and engine swapping questions!
Old Oct 17, 2001 | 07:10 PM
LshatchTurbo's Avatar
New User
Default Help! A/C and engine swapping questions!
Were doing a LS swap in my freinds Hatchback right now. I have previously done the same swap without A/C. His particular engine has the A/C belt and compressor intact and in good conditions. My question is can i use the compressor on the engine ro do i have to switch and use his civic one with a del sol vtec A/C engine moutn bracket? Thanks for your help!
Old Oct 18, 2001 | 07:16 AM
Kalokohan's Avatar
New User
Default Re: Help! A/C and engine swapping questions! (Zynentech)
I believe all b-series engines that are stuffed in 5th gen civics will require the a/c bracket from a del sol dohc vtec. Don't hold me to that. I have to get one of those damn brackets too for my hybrid. What year civic is it in?
Old Oct 18, 2001 | 08:25 AM
92sleepR's Avatar
New User
"switch and use his civic one with a del sol vtec A/C engine moutn bracket? "
Yes, that is the easiest and cheapest way.
Mike
Old Oct 18, 2001 | 10:00 AM
New User
Default Re: Help! A/C and engine swapping questions! (92sleepR)
Hmm. I was inspecting the A/C compressor comparing the civic to integra. This being a 92 civic and a 95 integra. The integra one is alittle bit bigger but still has all the same connecters. I might actually go ahead and experiment to see if i can use the integra compressor with the civic fans using some hoses. Not sure. Anyones input will help!
Old Oct 18, 2001 | 10:13 PM
GZR4DR's Avatar
You could Zynentech, however you will have to recharge your A/C system. I say just get the Del Sol bracket and call it good.
HNP
15
Aug 2, 2006 02:29 PM
vbherrera
Jul 17, 2006 12:47 PM
95excoupe
Jun 29, 2005 12:52 PM
wHOAlly
Aug 23, 2003 11:38 PM
Dr. Gonzo
10
Aug 3, 2003 07:38 PM
