LS vtec compression
Old Oct 22, 2001 | 03:19 PM
EVOCELICA's Avatar
New User
Default LS vtec compression
I want to know exactlly what compression I am running I have a B18 block with B18b rods and USDM ITR pistons and I am running a B16 1st gen head. Also the head is milled 40 thousands or so. Anyone have any Ideas, I was told it would be over 12:1 don't think that is true....
Old Oct 22, 2001 | 07:11 PM
EVOCELICA's Avatar
New User
Default Re: LS vtec compression (EVOCELICA)
some one please help me out
Old Oct 22, 2001 | 07:35 PM
rainforest's Avatar
it should be right about there in the 12.1 comp if my math is right. it prolly is wrong though.
Old Oct 23, 2001 | 11:14 AM
WAFFLES's Avatar
Default Re: LS vtec compression (rainforest)
I know for a fact the set up ranges from 11.1:1-11.2:1
I know cause this is my setup. pr3's put approx. 11.4:1 and usdm itr domes are less.
hope it helps evo.
Old Oct 23, 2001 | 02:35 PM
EVOCELICA's Avatar
New User
Default Re: LS vtec compression (WAFFLES)
yeah but compression is different depending on rods pistons block crank and the head. Plus my head is milled 40 thousands, there is no way that USDM ITR pistons with a b16 head milled 40 thou is 11.1:1
Old Oct 23, 2001 | 05:01 PM
1.8EG-T's Avatar
Yeah, 11.2 ish on the jdm itr pistons with no milling of the head(b16a), usdm itrs are 10.9 or so. But with that much milling, it should go well above 11.5, I agree it is around the 12.1 comp. ratio.
89hb
Dec 29, 2004 11:12 AM
TwoPointZero
Jul 23, 2004 03:46 PM
VTEC-DA
Jan 4, 2003 09:48 AM
Ruby Civic
Jul 28, 2002 03:40 PM
Stunna BEN
Nov 10, 2001 11:51 PM
