B series in EF???
Old Oct 22, 2001 | 02:57 PM
DR. ON POINT's Avatar
Banned
Default B series in EF???
I am thinking about buying a EF for a project car, but I would like to put in a b series motor. Now every mounting kit that I have seen has made the motor realy forward in the engine bay. I was wondering what mounts you could use other than place racing...Also if it is possible that you can post pics of ur b series motors in ur ef would be realy appreciative....thanks
Old Oct 22, 2001 | 03:15 PM
EVOCELICA's Avatar
New User
Default Re: B series in EF??? (On Point)
MAD mount kit
HASport mount kits
Place mount kits
HCP mount kits
Sorry no pictures, you could also reweld your mounts and position your motor where you want it.
Old Oct 22, 2001 | 03:44 PM
Jared's Avatar
I didnt use a kit, i cut and rewelded my mounts, used all 90-93 integra mounts and axles, here are the pics:
http://www.geocities.com/easttnimports/engine.html
BTW, these are preturbo pics, that is a B16.
Old Oct 22, 2001 | 05:03 PM
Katman's Avatar
one of my FFriends just hybrid'd his 90 civic Si w/B16 and Hasport kit. That bolt in kit rules. The motor sits way perfect. You can use an EF-SiR shift linkage with it no problem and 90-93 integra axles. No binding at all like some of them first bolt-in kits that came out about 1-2 years ago. There is some minimal vibrations, but that due to the urethane durometer (hardness) they use within the bolt-in kits mounts...
I highly suggest this kit. Look into it!
[Modified by Katman, 6:03 PM 10/22/2001]
Old Oct 22, 2001 | 11:38 PM
Newman's Avatar
New User
Here are picts of the HCP EF-18X kit.... look at the "fitment" page for more picts.
http://www.csuchico.edu/~dnewman/hcp
Old Oct 23, 2001 | 05:27 PM
fsarfino's Avatar
Default Re: B series in EF??? (Newman)
i would recommend you buy one of the bolt in kits and not weld in the mounts due to the critical placement of the welded in mounts could be off i had the welded mounts in my (totaled) 91 CRX Si and I always wished i would have bought the mount kit
Old Oct 23, 2001 | 05:32 PM
Jared's Avatar
Default Re: B series in EF??? (dohcvtec16)
the welded in mounts are tough to get wrong. you'd have to be an idiot. i like the welded option much better than the place kit anyway. i find the hasport, hcp, and weld in to be all about the same as preference goes.
Old Oct 24, 2001 | 07:45 AM
ATYPR's Avatar
Default Re: B series in EF??? (Jared)
Go with the Hasport mounts. We have them in the shop truck and have used them in other cars without a problem.
I have seen three cars with the welded trans mount break.
Old Oct 24, 2001 | 07:50 AM
Jared's Avatar
Default Re: B series in EF??? (FUCATYPR)
Bad welds break, they didn't break just because they were welded, only because they were welded badly.
Old Oct 24, 2001 | 09:24 AM
ATYPR's Avatar
True....so why take a chance. What if I want to pull my b16 and put the stock motor back in it to sell it?
Old Oct 24, 2001 | 10:05 AM
Jared's Avatar
If you have doubts about keeping the B16 then get a mount kit. I'm only saying that a rewelded mount setup is just as viable and strong as a mount kit. Not that one is better than the other.
Old Oct 25, 2001 | 10:42 AM
CLICC916's Avatar
to help out jared--the frame of your car is welded together...so are the stock mounts-holders....they are all welds...like jared said, it just depends on the quality of the weld and the welder himself. hasport mounts are welded together also. so don't worry bout welding if you know a reputable welder/shop. i personally prefer the hasport kit coz its easier on me, and i don't really know a good welder i can trust....
89civicracer
Oct 28, 2015 11:25 AM
guy_from_nerk
Mar 19, 2009 02:58 PM
F-Y-L
Dec 15, 2005 06:54 AM
DA6GSR
Jun 25, 2004 02:12 AM
DR. ON POINT
18
Oct 24, 2001 07:01 PM
