what to expect when starting up a rebuilt LS/VTEC motor??
New User
yesterday i started up my rebuilt block. i connected everything but gave me a funny noise. it started but didnt seem right. from some reason it was smoking from the inside of the valve cover, and it was making an awful sound. it sounded like it was the pistons not lubercated enough and the belt gave a lot more problem too. when on side of the timing belt is tight, the other is loose as hell. please i need some help if anyone can. thanks guys.
New User
Re: what to expect when starting up a rebuilt LS/VTEC motor?? (ls_vtecer)
if the timing belt doesn't have even tension on both sides i would DEFINATELY retension it. if you have that slack, it's going to carry over your sprockets, possibly skip some teeth.. then BOOM! not gonna be pretty..
did you lube the cylinder walls when you installed the pistons?
New User
Re: what to expect when starting up a rebuilt LS/VTEC motor?? (bojangs)
i remember lubing the cyclinder walls, but not that much though. everything was install properly but seems like there is not oil reaching the head. i dont know whats going on. please help.
teh Dirka
11-19-2008 08:35 PM
