wiring problem!! need help asap
Old Oct 6, 2001 | 11:44 AM
cervasa's Avatar
New User
Default wiring problem!! need help asap
im dropping a 94 b18b1 in my civic vx the stock harness wont connect to the teg ecu and the teg harness wont plug in what could be going wrong with this????
im in desprate need of help
Old Oct 6, 2001 | 11:58 AM
B18C-EJ1
Guest
Posts: n/a
Default Re: wiring problem!! need help asap (cervasa)
What? Sounds like you got the wrong parts.
The ECU should say P75, have two rows of pins, not 3. If it has 3 rows of pins, you have an OBD2 ECU.
Also, the 94 LS engine harness is plug and play in your VX, drops right in.
Old Oct 6, 2001 | 12:08 PM
cervasa's Avatar
New User
Default Re: wiring problem!! need help asap (B18C-EJ1)
thanx man ill go check it out and see whats up
Loughf
Jun 6, 2014 08:43 PM
hatchback33
Jun 2, 2010 10:42 PM
allmotorsi04
Dec 23, 2003 02:01 PM
Phoenix GSR
Mar 12, 2002 11:45 PM
