88 Civic/CRX rear lower control arms
I said I don't want a title!
Did the 88 Civic hatchback have the same rear LCAs as the 88 CRX did? I don't believe there was an 88 Civic Si, but what about the other 88 hatches (DX, standard, etc)? Need to know for autox postdate/predate rules, so I need the answer to be 100% accurate.
Thanks. These are going on a 91 Civic Si.
Re: 88 Civic/CRX rear lower control arms (Todd00)
All the 88 cars had the LCAs where the strut fits down into the LCA. And there was an 88 Civic Si.
Re: 88 Civic/CRX rear lower control arms (Jared)
one thing to remember, if the lcas came off a car that didnt have a rear sway(non-si) then there is not a nut for the endlink, however, adding one is not a problem
Re: 88 Civic/CRX rear lower control arms (court)
yeah the non si's have a hole absolutlly perfect to fit a sway bar on. and holes for the mountong brackets. I have a si sway on my dx. all i did was bore the holes for the top mounting peice. and keep the lca peices stock.
The_PissingDog_Crx
06-27-2003 11:56 AM
714phil
10
01-05-2003 05:02 PM
