Fuel pump
Old Oct 23, 2002 | 07:36 AM
dwilson's Avatar
Default Fuel pump
Could someone tell me if a pump off of a 92-95 civic SI 1.6 SOHC, is the same as a B- series pump?
Old Oct 23, 2002 | 10:39 AM
Hatchy-Ownzjo0's Avatar
H-T Poker champion
Default Re: Fuel pump (dwilson)
not the same.. but it will work with a B-Series engine. I think it actually runs at a higher pressure than the B-Series.. The worst that can happen is you will run a little bit rich.
Old Oct 23, 2002 | 10:59 AM
dwilson's Avatar
Default Re: Fuel pump (Hatchy-Ownzjo0)
is that good, will it hold up to the pressure a stock b-series will, reason im asking is i am currently running one on a turbo set up on a LS motor it has low fuel pressure cause i am running a hondata and rc 500 injectors. I know the B- series pump will hold up but i was just wondering if the SOHC SI pump would. Anyone else
Old Oct 23, 2002 | 11:11 AM
JD_B18CDX's Avatar
SOHC pump flows less than B series. It is was installed to support 120hp motors.
The b-serries (vtec) will be from 160-200hps.
If you floor it at high rpms, SOHC pump will not be able to sustain the fuel presure and run lean.
If you just putt putt around town it should be fine.
[Modified by JD_B18CDX, 3:12 PM 10/23/2002]
4drint3gr4
13
Jul 10, 2009 08:52 AM
blk_eg4
Aug 14, 2006 04:12 AM
Vtakkk
Feb 22, 2006 07:20 AM
EG2 SiR
Aug 19, 2003 10:46 AM
EG2 SiR
Aug 19, 2003 10:14 AM
