Which head to use on B20/Vtec?
Old Oct 22, 2002 | 10:08 AM
Bigjussin's Avatar
Default Which head to use on B20/Vtec?
Hey all, which would produce better all motor results, B16a Head, or my B18c head? Wont the B16a head have more compression, due to a small combustion chamber?
thanks mucho?
Old Oct 22, 2002 | 10:37 AM
xtrafastcivic's Avatar
Default Re: Which head to use on B20/Vtec? (bigjussin)
it's vice versa.....
Old Oct 22, 2002 | 01:33 PM
hawjdude's Avatar
i would say the b16 because lower compression and more air flow but this is if your going for turbo. IF all motor just get a type R motor.
Old Oct 22, 2002 | 03:24 PM
tinkerbell's Avatar
Default Re: Which head to use on B20/Vtec? (hawjdude)
i thought hte B18C head will create larger compression no.s.
see here:
http://www.c-speedracing.com/howto/c.../compcalc.html
also may depend on your choice of intake mainifold???
t..
PS dont mill the head too much.
Old Oct 22, 2002 | 07:40 PM
Bigjussin's Avatar
Default Re: Which head to use on B20/Vtec? (tinkerbell)
that calc kix azz. thanks mucho. I was a little confused about the head issue
Old Oct 22, 2002 | 08:09 PM
ahcjar103's Avatar
i like p72 heads. the squarish quench area is better when it comes to detonation, and the intake ports are more vertical. couple tenths more compression, blah...i like it
however, pr3 heads are also good. and if you're going to have the head modified at all, throw all the "pr3 heads flow 5% better" crap out the window.
ps. be sure to clay, especially with the pr3 head to make sure you're not tapping valves. easy problem with crvtecs due to the vavle reliefs on the pistons.
[Modified by ahcjar103, 5:10 AM 10/23/2002]
Old Oct 22, 2002 | 08:35 PM
1 2 NV's Avatar
Default Re: Which head to use on B20/Vtec? (ahcjar103)
i agree with this guy almost 100% although the GSR head FLOWS 5% better than the B16 head. the difference is the intake manifold. GSR also has .3 compression pts more than a B16 head.
Old Oct 23, 2002 | 08:23 AM
Micro's Avatar
I'm planning on doing this swap also... good info.
g0tgot
May 7, 2008 12:55 PM
zcme
Mar 2, 2008 04:12 PM
digital sol
Feb 1, 2005 07:58 AM
Whatever
Nov 8, 2002 03:34 AM
turbopanda
May 12, 2002 10:38 PM
