Check Engine Code 45
Old Oct 22, 2002 | 07:52 PM
Civikun1945's Avatar
New User
Default Check Engine Code 45
I have a friend that did an engine swap with his EK style Coupe. Now, the ECU is said to be Jap Spec. I don't know what that is but it sounds like a GS-R ECU because the Vtec crossover is heard at 4400?? and nothing near 5000. So, I assume that it is. But anyways, it is giving the code 45 he says. Is that possible? I had a OBD 1 ECU and on the maunal, i didn't find that code. If anyone can help this poor soul, please post the code for the 45. Thanks alot peoples.
Old Oct 22, 2002 | 08:06 PM
ahcjar103's Avatar
Default Re: Check Engine Code 45 (Civikun1945)
you need obd2 codes if it's in an EK, unless you pinned back to obd1
Old Oct 22, 2002 | 08:08 PM
New User
Default Re: Check Engine Code 45 (ahcjar103)
Yes, Thanks, but I am not even sure that if it is OBD 2, the person said that it was a computer from japan. I am thinking maybe it might be the same code as the OBD 2 because it fit staright to his OBD 2 Wire harness. Anyone? Thank you.
Old Oct 23, 2002 | 09:55 AM
CivicNewbie's Avatar
http://tech.hybridgarage.com/tech/codes.html
black_99SI
Dec 7, 2007 05:14 AM
RACING INTEGRATION
Oct 12, 2004 02:40 PM
lowboost civ
Mar 31, 2003 08:20 AM
