h22 help please?
Old Oct 17, 2002 | 04:15 PM
boostedcrx's Avatar
Default h22 help please?
ok I just bought a jdm h22a from hondamotorsonline.com and i'm putting it ina 97 prelude. Now the hard part: the jdm motor is an obd1 motor going into a obd2 car. So i am changing the harness and injectors and come to find out the obd2 motor has a cyl position sensor just behind the crank pully and the jdm motor doesent? so to make it work is it possible to wire up the where the cyl sensor used to be on the obd2 harness to the jdm(obd1) distributor (after finding out which sensor wire they are) OR should i just do the hard way and change the oil pump and use the cyl sensor thats on the obd2 motor? btw the sensor is mounted behind the crank pully on the oil pump, i'm trying to avoid pulling off the oil pumps and switching them.
help
Old Oct 17, 2002 | 04:30 PM
SilverEk3dr's Avatar
Default Re: h22 help please? (boostedcrx)
The thing is.....if your using your OBD2 ECU to run the motor then you have to put your other oil pump on the engine. Cuz there is 2 sensors on the oil pump that the OBD2 ecu uses (crank position, and top dead center sensor). Other than that your car wont run......
Mark
Old Oct 17, 2002 | 04:50 PM
boostedcrx's Avatar
Default Re: h22 help please? (SlvrEj6Dx)
ok thats what they are i didnt know what the proper terms for the sensors were, i figured that i had to swap the oil pumps not something i'm looking forward to. i've never messed with balancer shafts, ive been told to keep them "lined" up what does that mean? keep the indentation(markings) on both balance shaft gears facing each other? or away each other?
Old Oct 17, 2002 | 04:54 PM
well....you have to take out a bolt in the back of the block and put a screw driver in to line up one of them......the other has a notch on the pulley.....and you have to point it at an arrow on the block.....and all that has to be lined up with the timing belt with cyl. #1 at TDC.
Time to buy a Helms manual
Mark
[Modified by SlvrEj6Dx, 1:55 AM 10/18/2002]
Old Oct 17, 2002 | 04:57 PM
gritsak's Avatar
hey sorry to butt in on your topic, but i was wondering how your impressions were when the motor came from honda motors? i am about to order an h22, possibly from them and was wondering what kind of conditon it was and what all you got with the swap? is the shift linkage useable on the swap?.....thanx
Old Oct 17, 2002 | 05:03 PM
Default Re: h22 help please? (gritsak)
I know you didnt direct the question at me.....but it just so happens that I bought my h22 from HMO (about 4-5 months ago) it was from a 99 USDM prelude.......and I payed extra for the motor.....but it turned out great......I rag the **** out of it everyday.....and its given me zero problems
Mark
A Blue Lude
Feb 17, 2019 09:02 AM
caleba1
Aug 31, 2012 10:25 AM
CRXherbie91
Mar 9, 2009 10:05 PM
R@mon
Feb 7, 2007 03:47 PM
SPOOLINmatt
May 18, 2006 10:28 AM
