B21A1 Prelude motor swap into 91 CRX...........
Need to know basically how hard it is gogin to be and everything i need to do for it to go in. Plus any parts i need to change or get for it to run right. If anyone can help me i will greatly appreciate it.
I am doing this because everything is for free and i want to use it.
[Modified by BadWing10, 4:28 AM 10/24/2002]
Re: B21A1 Prelude motor swap into 91 CRX........... (BadWing10)
the b21 is one of the B series that doesn't share the normal block of all other B series, isn't it?
Anyway...even if it does, why would you want to do that?
Re: B21A1 Prelude motor swap into 91 CRX........... (hot_EG)
sorry....i'm a retard....someone can help Billy....
he got everything for free...and its all legit...so lets all help him
[Modified by hybridRhatch, 4:36 AM 10/24/2002]
not too hard, you gunna have to play "make the custom mounts" though...
if this puts you off, it may be pretty difficult...
teh engine is installed on a pretty weird angle in teh Prelude.
maybe take a look at a 88-91 Prelude engine bay and play "compare and contrast" with the current mounts in your CRX.
good luck!
t..
good luck!
t..
PS - that engine is a low revving stump puller - loads of tourqe, 6500 redline...
t..
t..
Re: B21A1 Prelude motor swap into 91 CRX........... (tinkerbell)
Even if you did manage to get that in.....you will now have what, 140 hp? Those B series motors from Honda are the oddballs. I should know. I have the B20a5 in my Prelude. I dog of a motor and runs out of breath before 7,000 rpm.
I like the 3rd gen Prelude body though.
You can check out my car at http://www.HondaPrelude.com
Set-up "Prelusions" 1989 SI Phoenix Red, non 4 Wheel Steering
This is a weld-in swap. Forget using Hasport mounts. Given the fact that the B21 is really not that great, I would forget about doing this swap.
stemiched
71
08-25-2006 05:42 AM
Sci_v_icI
14
03-03-2006 11:50 PM
