1st Gen B16a trans input shaft same as all B-series trannies?
basically i might be getting a CRX that i am going to keep with a b16 in it. my current car has has a 97 GSR swap with my JUN flywheel and ACT 6 puck clutch. i want to swap flywheels and clutchs,,,, WILL this work?> or are the number of splines different? thanks to all that respond
werd out
werd out
Re: 1st Gen B16a trans input shaft same as all B-series trannies? (1tyme)
the clutch is different if you use a cable tranny with the b16a.... you can swap your whole gsr swap in the crx with some work....
CivicSiRracer69
06-21-2008 12:30 AM
RHDwhor3
07-04-2005 10:05 PM
