mount question for 96 civic
Old Oct 15, 2002 | 06:16 PM
deviant1's Avatar
Default mount question for 96 civic
i noticed on the hybrid site they only mention needing the Si rear tranny mount for a B series swap. but on jspectuning.com/6gen they say you need the Si rear tranny mount AND the driver side Si mount (the one under the cam sprockets). the car is a 96 civic hatch. which is true?
Old Oct 15, 2002 | 06:22 PM
tonyxcom's Avatar
Default Re: mount question for 96 civic (deviant1)
you need both the REAR and mount and the DRIVER SIDE mount.
Old Oct 15, 2002 | 06:34 PM
deviant1's Avatar
Default Re: mount question for 96 civic (tonyxcom)
so three pieces all together? or just two? also, when you say mount, you mean the mount that is on the frame of the car or the mount that is bolted onto the engine and tranny itself? for the frame mounts i use mount and for the mounts that are on the engine and tranny i use bracket. that is, if anyone cares
Old Oct 15, 2002 | 06:36 PM
tonyxcom's Avatar
Sorry, yes the correct term in bracket.
You need the Rear SI tranny Bracket and
The SI driver side bracket (under belt cover)
Old Oct 15, 2002 | 07:00 PM
ekhatchhybrid's Avatar
i just did it u do need the mount that bolts to the block behind the dust cover under the sprocketts
ChinitodeNJ
11
Aug 10, 2009 01:45 PM
ProjectBoosted
Northwest (Sales)
Jan 22, 2008 07:05 PM
EJCivJdM93
Feb 9, 2005 04:40 AM
Scorch7
Dec 27, 2002 02:30 PM
GReddy SI
Dec 22, 2002 08:27 PM
