B16a2 in 90Teg??? HELP!
Old Oct 15, 2002 | 05:09 PM
its WANG yoO's Avatar
Default B16a2 in 90Teg??? HELP!
ok my cousin is swapping a b16a2 in a 90 integra Ls....
we are using his 90 Ls cable tranny...what clutch would he need to use? he's buying a clutch masters clutch and a flywheel too...so what would he get it for...90Ls or 99b16a2?
also...what mounts would we use....his stock Ls mounts???
ECU??...his car is 1990 which is obd0?? what ecu would he have to get?
thanks alot!!!
Old Oct 15, 2002 | 05:34 PM
ls_vtec_b18a1's Avatar
Default Re: B16a2 in 90Teg??? HELP! (hybridRhatch)
well the ecu u need a pw0 or a pr3 they are the same/ they will run u about 200.00 it will plug right in to your stock hardness.
Old Oct 15, 2002 | 06:27 PM
Default Re: B16a2 in 90Teg??? HELP! (ls_vtec_b18a1)
ok...any word on the mounts or clutch???
thanks alot...where can i find a pw0 or pr3???
Old Oct 15, 2002 | 06:37 PM
honda tech classifeds there are some on there now for lik 160.00 good buy
Old Oct 16, 2002 | 03:41 AM
Jeff C's Avatar
clutch:
he needs to buy one for a 90-91 teg because it has a smaller spline (25mm) than the 92+ tegs (26 mm).
mounts:
the car came with a b-series motor so he wont have to buy new mounts.
Old Oct 16, 2002 | 06:16 PM
Default Re: B16a2 in 90Teg??? HELP! (Jeff C)
thanks alot!
pwo- is from what car? and it will work?
pr3- " " " " " " " "
Old Oct 16, 2002 | 06:30 PM
Kamin's Avatar
when you say b16a2
do you mean a second gen b16
or a b16 out of a civic SI.
also wouldnt it be easier just to get a first gen b16?
Old Oct 17, 2002 | 03:59 AM
Jeff C's Avatar
Here are the different ecu's...
http://www.hondaswap.com/reference/index.php?mode=ecu
Either one of those ecus should be ok. He might cosider getting a chipped P28 if he is not on a tight budget, that way you can do away with the knock sensor and second O2 sensor (I think the JDM motors have 2 O2's ).
Old Oct 17, 2002 | 06:10 AM
pissedoffsol's Avatar
25 Year Member
seriously- b16a SiR that puppy and save half the cost, and the hassel
Old Oct 17, 2002 | 11:24 AM
Default Re: B16a2 in 90Teg??? HELP! (delvtecsol)
its a B16a2 from a 99 Si...i think i posted that in the add above...he got a good deal on it from a junkyard...$1000 for motor...so thats why we are doing it...
thanks!
P28 ecu won't work...his car is OBD0 i believe...its a 90'
Old Oct 17, 2002 | 12:02 PM
Jeff C's Avatar
you are correct, but you could convert it to obd1
my buddy, 91civicsi, is running his 95 gsr powered 91 hatch on a PM6 (civic si ecu) with the Zdyne One Wire Coversion...it runs great. Maybe your friend could check into that.
[Modified by Jeff C, 4:02 PM 10/17/2002]
Old Oct 17, 2002 | 04:57 PM
hmmmmmmm
where do i find this??? Zdyne!?
Old Oct 17, 2002 | 05:03 PM
Kamin's Avatar
dude saveyourself ALOT of heacaches
sell the b16a2 swap for about 2500$
buy a first gen b16 and use the 1300$ you saved to upgrade the cams, intake manifold clutch and flywheel.
Old Oct 18, 2002 | 09:34 AM
Jeff C's Avatar
check it out
<FONT COLOR="red">the reason we used this on my buddy's swap though is because we already had it.</FONT>
[Modified by Jeff C, 1:35 PM 10/18/2002]
globy123
56
Sep 16, 2018 05:53 AM
raverx3m
Feb 26, 2015 10:48 PM
streetsold6teeny8
Mar 4, 2009 02:39 PM
