What do i need to do to switch my 93 gsr motor into a 96 civic hatch????
i have a b17a(93gsr)in my crx with hcp mounts and gsr spindles. the tranny is also cable. the shift linkage has been modified to fit my car(gsr). the wiring harness was converted to obd 1.
i was thinking of using some stock integra mounts, si rear bracket, integra throttle cable, and hasport hydro cable conversion(should i sell the my tranny and get a hydro? The one I have works perfect) i was going to use the harness off the crx (will that save me trouble? Since the civic is obd 2). should i get another shift linkage or modify it back to fit the civic? will the gsr spindles swap right over? Any info would help. thanks
Re: What do i need to do to switch my 93 gsr motor into a 96 civic hatch???? (wickedxboi)
get a hydro tranny.
99 SI rear tranny bracket.
99 SI Driver side bracket.
Use your stock lower torque mounts on the civic.
Use your stock rear torque mounts on the civic.
Use the stock upper tranny mount/bracket on your civic.
Use the stock drivers side mount on your civic.
Any B-series A/C mount. (Delsol P54 if you want to keep AC)
Delsol, 99SI, DC Shiftlinkage and axles.
MUST USE 96-98 Engine Harness - EX preferred.
Correct Adapter to use whichever ecu you choose.
[Modified by tonyxcom, 7:04 PM 10/29/2002]
tRex99
01-29-2005 03:23 PM
