f22a or h22a into an EF chassis.
Anyone done this? If so how much did it cost, and how hard was it? Yes I've search but I want an opinion from you.
Guest
Posts: n/a
Re: f22a or h22a into an EF chassis. (tzsir)
first off
can you weld?
do you know or have access to the wiring of both the ef chassis and a h -series motor
you need to move the fire wall back about 6-8 inches to clear the h-series motor. as well as reinforcing the engine bay after cutting alot of it out is also necessary. if its your first swap think b-series. they are designed for that chassis
late
can you weld?
late
Re: f22a or h22a into an EF chassis. (civeg)
move the firewall back 6-8"?
Where did you get that info? Maybe if you're making your own mounts.
Check out the Place Racing mounts bro.
