evap purge solenoid ?
well i have a 93 cx and the motor is jdm b16a and the question is how do i hook up the evap purge solenoid i know its a red wire and it goes to a20 on the ecu pinout but how do you wire it up . help will be apriciated ..........
New User
Re: evap purge solenoid ? (Cx Sir II)
It is just a solenoid so its pretty easy. It has a negative (ground) trigger from the ECU which means that when it is activated the ECU grounds the red wire on pin A20. The other wire is an ignition switched +12v from the main relay.
just connect the red wire to pin A20 and check for +12v on the other wire when the key is in the on position.
Mike
Mike
New User
Re: evap purge solenoid ? (HybridEkCivic)
In all honesty no, but the 'green' in me prefers to have it working. It doesn't hurt anything. It is part of the visual smog check as well so it should at least be present.
Mike
Mike
dingusjt
11-13-2003 10:18 AM
T25 civic
10-06-2002 02:11 PM
