B18A mounts same as B18B?
Old Oct 22, 2002 | 03:20 PM
specie's Avatar
Default B18A mounts same as B18B?
I'm putting an ls motor in my '95 Integra. Are the '92 motor mounts the same as the '94 up? Thanks.
Old Oct 22, 2002 | 04:17 PM
Jared's Avatar
Default Re: B18A mounts same as B18B? (specie)
No
Old Oct 23, 2002 | 06:53 AM
specie's Avatar
Default Re: B18A mounts same as B18B? (Jared)
Thanks. Are any of the mounts reuseable or is that a NO go also?
Old Oct 23, 2002 | 10:41 AM
Hatchy-Ownzjo0's Avatar
H-T Poker champion
Im not sure about this.. But in my swap into my 93 vx hatch i only needed the passenger side lower transmission mount from the integra.. i think you might need the rear mount as well.. i dont quite remember..
Edit: But that was with CIVIC mounts.. so im not sure if the same goes for the teg mounts.. i assume it does.. but i would think the mounts were the same from integra to integra.. its the same engine.. why not the same mounts?
[Modified by Hatchy-Ownzjo0, 2:42 PM 10/23/2002]
Old Oct 23, 2002 | 05:09 PM
StorminMatt's Avatar
1990-1993 and 1994+ motors use different driver's side and rear transmission brackets. Just get the right brckets and the motor will drop in fine.
Old Oct 23, 2002 | 06:14 PM
AZcivicHeat's Avatar
Default Re: B18A mounts same as B18B? (StorminMatt)
hey hatchy did you use teg motor mount inserts or not? my friend is telling me i have to do this in order for everything to go in nicely in my 93 civic
Old Oct 29, 2002 | 06:57 PM
specie's Avatar
Default Re: B18A mounts same as B18B? (AZcivicHeat)
Are the '94 up LS and GSR mounts the same? Thanks.
CRXDRU
17
Dec 1, 2012 05:30 AM
JDM_NANO
29
Oct 3, 2011 04:15 PM
smokey.23
22
Mar 24, 2009 09:01 PM
white_db8
May 26, 2007 09:34 AM
futurefastguy
Jun 9, 2006 11:05 AM
