B20 Injectors
Old Oct 24, 2002 | 11:28 AM
VitaminB20's Avatar
From: Where the grass is green and the girls are pretty.
Default B20 Injectors
What CC are Stock B20 injectors? 210cc? Can I keep them for a B20vtec swap?
Old Oct 24, 2002 | 11:34 AM
JCushing's Avatar
Default Re: B20 Injectors (VitaminB20)
240cc
Old Oct 24, 2002 | 02:36 PM
VitaminB20's Avatar
Default Re: B20 Injectors (JCushing)
Is 240cc good enough to keep for a B20vtec swap?
Old Oct 24, 2002 | 02:45 PM
JCushing's Avatar
go to rc engineerings web site http://www.rceng.com
everything you need to know about injectors.
Old Oct 24, 2002 | 02:52 PM
VitaminB20's Avatar
I see that you have a B20 swap, what injectors are you using?
Old Oct 24, 2002 | 02:57 PM
JCushing's Avatar
240cc b18b injectors.. the ones from my b20 were dirty... running 46 psi
if you were to run a b20 vtec you would prolly want 45 psi on 240's with a good amount of fuel added up top.. this might max out your stockers.. try 270 or 310 cc... this will allow you to run nice and low fuel pressures
[Modified by JCushing, 6:59 PM 10/24/2002]
Old Oct 24, 2002 | 03:01 PM
VitaminB20's Avatar
Is there a way to clean the injectors to new condition? I want 310cc RC injectors but can't afford them at the moment.
Old Oct 24, 2002 | 03:05 PM
JCushing's Avatar
you can get them balanced and blueprinted.. this makes them just like new... rc engineering does this for 100 bux a set i belive...
Old Oct 24, 2002 | 03:08 PM
VitaminB20's Avatar
Thanks, you've been great help. Would you happen to know if the B20 injectors will fit into my 98 D16Y8?
Old Oct 24, 2002 | 03:14 PM
JCushing's Avatar
dont know try it...
Old Oct 24, 2002 | 08:17 PM
tinkerbell's Avatar
dont know, why dont you try it...?
sorry, it just reads better...
t..
Old Oct 24, 2002 | 11:09 PM
Brad's Avatar
I think b and d series injectors flow the same, 235-240cc, just to let you know if you're just swapping them. I've used d-series injectors in a b-series motor and it worked fine, so they will probably fit the other way around.
Brad
Old Oct 25, 2002 | 12:17 AM
VitaminB20's Avatar
Default Re: B20 Injectors (Brad)
Does anyone know what size are the D-series injectors? 185cc?
Old Oct 25, 2002 | 01:08 AM
Brad's Avatar
240 cc I'm positive about this now.
Old Oct 25, 2002 | 01:19 AM
VitaminB20's Avatar
Same as B20 injectors?? Damn, no use replacing them then.
gonmaro
Apr 1, 2009 07:14 PM
jesusjdm69
Mar 27, 2009 10:58 PM
sketchaholic
10
Sep 13, 2006 10:21 AM
jAUTOek4
Jun 21, 2006 11:54 PM
