ZC swap code 9 (cyl sens) so close, yet.....
Im getting a code 9 (cyl sen) and I have taken the pins out, switched wires,switched wires again just to make sure and no change. I have tested ground in sensor and pins and even looked at the signal on a snap-on vantage, everything looks normal. This of course answers my last post about my engine being flat under load. But I have noticed that under load my temp. gauge is irratic and when Im of the gas it returns to a accurate reading. I feel this might have something to do with it but ?
I have the cyl. sen. running to c1 c2 the first pins on the C connector( over,under) on the ecu Im sure thats the right location. So if you guys can help out please do.
Re: ZC swap code 9 (cyl sens) so close, yet..... (Pcart)
If you come to the point where you want to purchase another cylinder position sensor I have one for sale. It was one of the things when I was trying to find out what was wrong with my car.
wire that was originally at c1 needs to go to B connector 5th pin from left - bottom row - - wire that was originally at c2 needs to go to B conn. 6th pin from left - bottom row - - new wire from c1 to blu/grn on cyl. pos. sensor - - new wire from c2 to blu/yellow on cyl. pos. sensor
