Can someone tell me what these wire are? obd1 & obd2 gsr
Old 10-22-2002, 04:19 PM
lost password's Avatar
Default Can someone tell me what these wire are? obd1 & obd2 gsr
This is a 95 gsr with a converted obd2 engine harness (I swapped over the inj,dist,alt plugs)
This is the only plug left.
The car side has 2 wires red & yel/blk ( evap purge solenoid I think)
The obd2 engine harness has 3 wires wht/red blue/red red/yel (evap purge solenoid I think)
Can someone tell me what these wires are for sure? And/or how to hook them up?
Old 10-23-2002, 01:53 PM
Default Re: Can someone tell me what these wire are? obd1 & obd2 gsr (lost password)
bump
Old 10-26-2002, 09:06 AM
kenji's Avatar
That plug with three wires on the OBD2 engine harness is for the CKF and the signal wire for the EVAP purge solenoid.
The wht/red and blu/red wires are for the CKF and the red wire is for the EVAP purge solenoid.
If you are OBD1 you can forget about that plug. If you want to wire up the purge solenoid that is fine but it will have no affect on performance.
If you have any questions just ask.
-kenji
Old 10-26-2002, 11:20 AM
Default Re: Can someone tell me what these wire are? obd1 & obd2 gsr (kenji)
Thanks
I really appreciate it
Had no idea I didn't need to hook up the purge solenoid.
Alex Preece
10-24-2018 10:31 PM
dar5052
12-19-2011 09:29 AM
EfSedanLove
04-02-2008 10:54 AM
k624ash
08-16-2007 02:15 PM
ATX45
06-10-2006 06:24 PM
Quick Reply: Can someone tell me what these wire are? obd1 & obd2 gsr
