b20b and h22a long block specs?
Got a lil question here,,, i looked on hondamotorsonline.com and other places but can't find the specs on the h22a long block compared to regular h22a.. and what are the diff's? Also the B20B... Is anybody running this motor??? I mean its a wannabe suv motor... is it good at all? it cant be a true b series at 795..lol thanx o yah is the b20b long block vtec?
Re: b20b and h22a long block specs? (98Hatch22a)
Yah the difference between h22 regular and h22 longblock is like the difference between regular and premium gas... the longblock is actually 5mm longer and thus creates a better rod/stroke ratio... with this honda is able to squeeze an extra 15hp out of the motor.
As for the B20, the B20V is the only b20 that comes with VTEC...
and yes it truely is B series, the only motor that isnt consider'd B series would be the B17 because original spec was for it to be V spec to compete with nissan.
Yes the B20Z/B is a B-series engine. I'm waiting to put one on my car now...still collecting parts!
It's similar to a B18B only with a wider powerband. Keep in mind if you are starting with D-series engine and want to swap it with a B20Z/B, you have to replace tranny, axles, shift linkage, clutch, flywheel...etc.
Re: b20b and h22a long block specs? (sirhatchback)
Sirhatchback,
What are you smoking? A regular H22A probably comes with motor tranny, ecu, and such. But a H22A longblock comes with just the motor - oil pan to valve cover.
Re: b20b and h22a long block specs? (sicivic)
Sirhatchback,
Sirhatchback,
are you really serious? there was no b20v or any b20 with vtec from factory... The difference between a complete h22 and an h22 longblock is a complete h22 comes with motor/tranny/ecu while a longblock is just the motor with no tranny or ecu... It has nothing to do with the rod/stroke ratio... a b17 is considered a b series there is nothing like a v spec in honda.... geez, get your facts straight before you post
sorry, i didnt know you were joking.....i know a guy that bs's about everything and just makes up stories like that and thinks he's the **** so i got a little worked up...
