H22a Distributor
Old Oct 20, 2002 | 05:37 PM
BigBank420's Avatar
Default H22a Distributor
I inspected the new swap today and found the distributor happens to be a internal coil unit but the shaft and bearing are shelled out. Now I know it's hard to find a dist.like this so Im wordering if I can gut it and install the internals from a 92 accord vtec dist or will I need a different type of dist to get the parts from. Any help would be greatly appreciated.
Thanks,
Andy
Old Oct 20, 2002 | 11:07 PM
poison's Avatar
Default Re: H22a Distributor (BigBank420)
Andy,
Yes, you can use 92 accord vtec dist and will go in no problem.
BTW, assuming the H22A is OBD1 as well.
Old Oct 21, 2002 | 03:47 AM
BigBank420's Avatar
Default Re: H22a Distributor (poison)
Thanks alot for the info. And yes it is OBD1 so everything should work ok then.
Thanks,
Andy
Crxh22ajdm
May 1, 2013 11:34 PM
Stoich EG2
Dec 15, 2004 06:35 AM
Honda Sport
Apr 28, 2003 05:37 AM
