knock sensor
Old Oct 21, 2002 | 06:06 AM
dose's Avatar
Default knock sensor
i kno where to wire it in the ecu but where do i hook it up on the motor
Old Oct 21, 2002 | 09:51 AM
Kataku2K3's Avatar
Default Re: knock sensor (dose)
straight to the KS on the back of the block under the manifold. It's a single pin sensor that uses a 2 pin plug. If you have an LSVTEC or something along those lines you will need a KS and tap ur block so that it will thread in. If it's something that comes with a KS like a GSR or B16 just run it straight to it.
Old Oct 21, 2002 | 12:41 PM
poison's Avatar
Default Re: knock sensor (JDMspecEG6)
very good info
Old Oct 21, 2002 | 01:17 PM
B_CRUZ!'s Avatar
pics *borrowed* from thee FF THE RAPIST
Old Oct 21, 2002 | 01:49 PM
dose's Avatar
anyone kno wher i can get a plug to go in there
Old Oct 21, 2002 | 02:39 PM
PhatOptimo's Avatar
Someones old JDM harness. Ask around.
Old Oct 21, 2002 | 06:25 PM
B19CivicHB's Avatar
hook it from the ecu (D3) to the red/blue wire on the car side of the passenger side harness plugs.
HTH,
-Nick-
Old Oct 22, 2002 | 02:32 PM
Kataku2K3's Avatar
Default Re: knock sensor (B19CivicHB)
As long as you line up the new wire with the right pin in the plug you should be able to use any 2 pin plugs. IACV, ECT, ECTs, IAT I probably forgot some of the two pin plugs but i can't think of anymore right now. If you could i would just try to fnd a actual KS plug. I just like it when the wiring looks clean. Good luck
Old Oct 22, 2002 | 04:11 PM
tonyxcom's Avatar
I can sell you the the KS plug. I will cut it off one of the two harnesses I have laying around.
$10 Shipped. I will leave at least 6" of wire on it for you, but probably more.
burntheblobs
Jun 28, 2007 04:21 PM
quicky_hatch12
Oct 7, 2005 11:59 AM
93si-hybrid
Jul 15, 2004 01:09 PM
T_Rex
Feb 3, 2003 07:43 PM
92hybridhhatch
Feb 12, 2002 12:34 PM
