Help with b16 problem......
Old Oct 21, 2002 | 07:21 AM
crxgurlllll's Avatar
Default Help with b16 problem......
b16 into my 91 si....put her in started her up no codes ran perfect for 50 miles or so
Today while accelerating the engine just stopped for a second then started back up(it was still in gear) it got worse and worse until I could no longer restart the car at all....
I know its getting spark its got fuel at the rail, there is no codes at all
I took out the injectors and cleaned them off with brake cleaner and put them back in. Changed the fuel filter also. All it does when I start it is back fire a little bit......
thanks for your help
_________________________
bad ignitor= no spark....im getting spark....
tried different computer as well and still nothing.....
getting backfire so that leads me to believe im getting spark but slim to none on fuel
____________________________
the car wouldnt just run perfect then start not running/running like crap if the plug wires were in the wrong sequence.....
ive checked and rechecked all the grounds....
________________________________
does anyone else think it could be injectors? main relay?
also remember that this car RAN PERFECT for about 30 minutes
Old Oct 22, 2002 | 09:39 AM
poison's Avatar
Default Re: Help with b16 problem...... (eraser)
This may sound 'stupid', but trust me. I've seen this exact problem.
Check your connections to the alternator, reseat the connectors to them, as well as MAKE SURE the bolt on there is tight and not stripped.
Your alternator may be bad and not delivering the full charge it needs.
Old Oct 22, 2002 | 04:20 PM
Jared's Avatar
are your injectors firing?
ktecCRV
Honda CR-V & Element
May 15, 2026 04:05 PM
BONNARSKI
12
Jan 7, 2013 02:42 AM
hondabro1988
Jul 31, 2012 02:55 PM
b16hatch
Feb 19, 2003 05:47 AM
crxgurlllll
Oct 21, 2002 10:39 AM
