96+LS to 92DX
Old Oct 16, 2002 | 09:03 PM
s.khang's Avatar
Default 96+LS to 92DX
I know that the 96+ LS motor is OBD-2 and my car is OBD-1, will I need to change any wiring? Is there anything else that I will need to change? Can someone help me out? Thanks.
[Modified by red92hatch, 5:23 PM 10/17/2002]
Old Oct 17, 2002 | 08:24 AM
s.khang's Avatar
Default Re: 96+LS to 92DX (red92hatch)
Old Oct 17, 2002 | 06:42 PM
VTECVillain's Avatar
Super easy solution: use an OBDI LS ecu and problem solved. You can run a full OBDII motor with the OBDII engine harness but use the OBDI ecu that plugs into your cabin harness. Bolt it in, hook up the plugs and enjoy......... it almost that easy!!!!!
Old Oct 17, 2002 | 09:13 PM
s.khang's Avatar
Default Re: 96+LS to 92DX (VTECVillain)
cool. thanks.
4thgenlude
13
Oct 24, 2006 10:46 AM
sik96teg
16
May 26, 2006 11:23 AM
SpoonyGSR
Jan 28, 2004 03:11 AM
tremor86
Feb 6, 2003 10:29 AM
twitchm80
Oct 10, 2002 01:59 AM
