bad idle HELP
Old Oct 25, 2002 | 04:30 AM
slap's Avatar
Default bad idle HELP
I just put a 2000 LS motor in my car on Tuesday. I have a 93 Civic DX Hatch. I am using the stock harness with a 95 LS ecu. There is something wrong with my idle. With the AC button switched to on, the motor seems to idle properly. But with the AC button turned off the car studders and dies. All in all it is revving up and down, up, down, up, down... and so on. The AC is not hooked up either. How can I fix this? HELP ME PLEASE. I am clueless.
Old Oct 25, 2002 | 04:55 AM
twitchm80's Avatar
Default Re: bad idle HELP (slap)
check you timing sounds like its retarded cause when you hit the a/c button it ave. your timing and runs well
Bhi Rds
May 8, 2016 06:19 PM
Rooftop-Special
Sep 2, 2010 08:08 PM
Andrew14
Jun 22, 2010 09:24 PM
AnthrPludedriver
May 22, 2007 07:40 AM
