piston to valve clearance on a b20/vtec with stock pistons
ok i have the 8.8 cr pistons in my b20 now and i want to put in b20z pistons (9.6:1) in my b20 when i do my vtec conversion (prolly with a b16a head) this will put me at 10:1
basically will b20z pistons hit the valves with no advance of timing? ive been looking for answers for days now and i cant find anything for sure..
as far as claying i would but i dont have a head yet or pistons.. i just want to know if phk pistons will work before i order them
and yes i know the best route would be forged pistons but $ is an option here so i want to know if these pistons will work not your opinion on what would be a better setup.
[Modified by JCushing, 7:51 AM 10/23/2002]
Re: piston to valve clearance on a b20/vtec with stock pistons (daver)
he was using b20b pistons with a lot milled off the head, i already asked him...
Re: piston to valve clearance on a b20/vtec with stock pistons (JCushing)
I thought on a Z they would hit. But you could dremel out the valve reliefs a bit and they would work. How much though i'm not sure.
Re: piston to valve clearance on a b20/vtec with stock pistons (nsxmatt)
im pretty sure you just need to widen them to fit the larger vtec valves ie there made to accept a smaller non vtec valve
darkintegra
54
06-26-2017 09:19 AM
