help!!95 gsr throttle body and iac question???
on the iac there is two hose connection what goes where??also on the throttle body there is two hose connections..what goes where?? please help ..working on car as we speak...thanx in advance..its in a 95 gsr
Re: help!!95 gsr throttle body and iac question??? (another_import)
on iacv you need to connect coolant lines. on the tb, i dont know w/c ones you're talking about. picture would help
Pics would be very helpful. On the TB, there are 2 coolant connections under the TB air inlet. These are coolant connections also. These connections are for the Fast Idle Thermal Valve.
I think there is a vacuum connection on top of the TB also. This connection is to the evap canister.
dem0nk1d
14
03-22-2006 05:57 PM
4DRmafia
09-03-2005 10:17 AM
