** GSR ehxaust manifold on LS REX???? HELP!!! **
hey everyone....... im pullin the turbo off my LS rex this weekend, cause im going to go bigger after i sell this turbo...... and i dont have the stock LS manifold but my friend gave me a OBD-I GSR exhaust manifold ( 94 i believe)...... will this fit on my rex with the LS??? is it long enough to reach the cat???
thanks!!
boostinb18
thanks!!
boostinb18
Re: ** GSR ehxaust manifold on LS REX???? HELP!!! ** (boostinb18)
The GSR header is slightly shorter than the LS so you will need to have your exhaust lengthened. It also doesn't have a hole for the oxygen sensor but that's an easy fix - drill hole and weld on proper sized and threaded nut. BTW, what type of turbo setup do you have that you are going to be selling?
Re: ** GSR ehxaust manifold on LS REX???? HELP!!! ** (VTECVillain)
cool! thanks!
i have a dc sports 4-2-1 bottom half that i might throw on to the gsr top half... it was extended to fit and has a o2 bung........... the turbo is a greddy tdo4h-15g sohc kit..... that i modded to fit on my B18B.
