Code 9 after obd1 conversion...
Old Oct 17, 2002 | 10:30 PM
02WRX's Avatar
Default Code 9 after obd1 conversion...
Ok, I am converting to obd1 from obd0 in a 90 Civic with a b16a. I've gotten an ECU from Katman, the conversion harness from Jason (Blown90Hatch) and an OBD1 distributor from Brian (b18c1_powered_si).
I all the wiring done, including re-pinning the distributor to obd0 plugs, then went to fire it up. No dice. The car turns over, but doesn't catch. Jumper the codes, I get a 22 and a 9. So I check the wiring on the harness & dizzy. I wasn't sure about wires 9 & 6 on Jason's conversion harness (6 is vtec oil pressure, 9 is secondary butterfly for a gsr intake/ecu), so I switched them. Code 22 gone. I also wasn't sure about the wiring on the dizzy. Most of the wires are easy enough, but as some of you certainly know, obd0 dizzy's have two white wires. In any case, I tried a number of different changes in the pinning of the dizzy, but all I ended up with is a code 78, which I can't find.
In any case, if anyone who's done an obd0-obd1 conversion can post a definite wiring layout for the dizzy, that'd be great. If anyone else has any ideas on why it won't fire up & where the code 9 is coming from - any help would be appreciated.
One final, stupid question....
Is the distributor firing order the same on an obd1 dizzy as an obd0 dizzy? (I'm assuming it is, but....)
Thanks,
Eric
Old Oct 18, 2002 | 06:43 PM
lelopez's Avatar
Default Re: Code 9 after obd1 conversion... (90CivicEX)
I've done quite a share of obd0 to obd1 conversions and sell conversion harnesses as well. The wiring to the distributor follows the same color code as the obd0 distributor. If you already tried to switch around the two white wires just in case you had them reversed then my guess is that it is possible for you to have a bad dizzy.
Code 9 is the TDC sensor and unless you have your engine completely out of timing, then I have to assume it is a bad sensor on the dizzy. Hopefully I'm wrong, but this is what I've seen in my experience.
My other guess would require you to answer if your civic was a dual point. I assume it is not because of your signature (90CivicEX). But if your civic used to be a dx make sure you did the proper dx to si conversion.
good luck,
Lester
Ash J. Williams
Dec 24, 2012 01:02 PM
Hondamonster
Jul 29, 2007 05:25 PM
Ruby Civic
Mar 11, 2004 09:08 PM
02WRX
Oct 18, 2002 09:01 AM
