Code 78??? WTF!?
Old Oct 18, 2002 | 09:09 AM
02WRX's Avatar
Default Code 78??? WTF!?
So I'm converting to obd1 from obd0... For more details, see my post in Hybrid https://honda-tech.com/zerothread?id=309958
Ok...after fixing the firing order & swapping the 'white' wires again, the code 9 is gone. The car starts. Unfortunately, I'm getting a code 78? I can't even find a code 78 listed in my trouble code printout. But when I toggle the code switch, I get seven long flashes, followed immediately by 8 short flashes, then a pause & repeat. Any ideas?
Thanks,
Eric
Old Oct 18, 2002 | 09:19 AM
EP3_05's Avatar
Default Re: Code 78??? WTF!? (90CivicEX)
I did a little research and I can't find that code either...What ecu are you suing in your conversion?
Old Oct 18, 2002 | 09:34 AM
02WRX's Avatar
Default Re: Code 78??? WTF!? (91civic)
It's one Katman did for me. With the jumper on it engaged, it's close to a p30 program off the eprom. With the jumper disengaged, it's a stock p28.
Eric
Demambro
Apr 12, 2017 10:11 AM
blkcivic310
Jul 13, 2010 08:18 AM
eg_gsr11
Nov 18, 2006 05:48 PM
hotimportcrx
Oct 3, 2005 11:22 AM
