88-91 crx k motor info
i need so more info on putting a k motor in a 89 crx
..wiring harness does it jsut plug in or do you have to splice into the wires
..motor mounts cut and welding
..halfshafts? what kind or does somebody make some to fit
..the shift linkage or cable? what do i use
..header use the stock one or aftermarket?
..what ecu and does anything need to be done to the ecu?
..any other info would be nice too little hints anything that you did to your rex to help me out
thanks for your time
later
later
Re: 88-91 crx k motor info (DELSLOWEST)
There is a bunch on info on this swap you just need to search for it. To answer some of your ????'s
1. HASPORT is making a motor mount kit but it WILL include a weld-in mount.
2. You'll need to purchase an aftermarket header to clear the firewall.
3. You need a KPRO
4. Wiring harness for plug & play install will be provided by HASPORT $350 range.
5. HASPORT will offer axles for the swap...$300 range.
6. HINTS...
Be ready to buy a new hood!
3. You need a KPRO
6. HINTS...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DELSLOWEST »</TD></TR><TR><TD CLASS="quote">what is a kpro?
and what ecu do i use
later</TD></TR></TABLE>
K-pro is hondata's reprogramming of the stock ECU (PRB=k20a2 PRC=jdm K20a type R)...K-pro is fully programmable...including cam angles (the "i" in i-vtec)
hope you have atleast $8000...I am up over $10,000 & don't even have it installed yet
search - its all be covered before you'll need everything for a EG/EK/DC + more
