B18 vs B20
Old Jan 1, 2005 | 11:10 AM
OldSkoolEskimo's Avatar
Default B18 vs B20
Do the B18 and B20 use different blocks or does the B20 have a larger stroke and/or bore to get the larger displacement? And why has the B18 become so much more popular than the B20?
Old Jan 1, 2005 | 12:46 PM
CRX_1.8T's Avatar
Default Re: B18 vs B20 (OldSkoolEskimo)
A lot of it may have to do with availability. There are probably more Integras than CRV's on the road.
Old Jan 2, 2005 | 07:40 AM
Alex33's Avatar
The B20b has thinner cylinder walls and weaker rods than the B18b. If you look at the specs on the two, you'll see that the B20b is just a B18b w/ a bore of 84mm instead of 81mm. Hope this helps.
Old Jan 2, 2005 | 10:55 AM
Plugs's Avatar
Default Re: (Alex33)
If you want a b20 make sure its a B20z2.
Old Jan 2, 2005 | 10:59 AM
AngelTeg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Alex33 &raquo;</TD></TR><TR><TD CLASS="quote">The B20b has thinner cylinder walls and weaker rods than the B18b. If you look at the specs on the two, you'll see that the B20b is just a B18b w/ a bore of 84mm instead of 81mm. Hope this helps. </TD></TR></TABLE>
this is not entirely correct.
A b20 uses an awkward "siamese sleeve" design where the sleeves all share a wall, rather than being 4 independent sleeves, like in a B18.
B20 rods are absolutely identical to B18B rods.
when it comes to part selection, you can treat a b20 as an LS with an 84mm bore.
B18 blocks are more popular because there are more of them, and they are typically cheaper than B20 blocks.
-Mike
Old Jan 2, 2005 | 06:58 PM
b20_ed's Avatar
Default Re: (ickabod)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ickabod &raquo;</TD></TR><TR><TD CLASS="quote">If you want a b20 make sure its a B20z2. </TD></TR></TABLE>
or just b20z
some b20b's have a 9.2:1 cp, or something like that. this topic has been beaten to death..i can go on..
Old Jan 2, 2005 | 09:02 PM
Alex33's Avatar
Default Re: (AngelTeg)
thanx for mentioning that, it completely slipped my mind. btw, this trial user thing sux anus, hahaha
Old Jan 3, 2005 | 12:02 PM
Plugs's Avatar
I have a Mildly Built 2000 b20vtec for sale. Pm me for details.
Old Jan 3, 2005 | 07:46 PM
thx, all this helps. I dont have a license or car yet but i am pretrty sure i am gettin a civic ek hatch. I mite be interested in the built B20vtec in a year or two
Old Jan 4, 2005 | 02:57 AM
POWERLINEDOHCtor's Avatar
Default Re: (OldSkoolEskimo)
Call r-crew, or go through me if you want em cheaper, Dan only sells the b20's as long blocks. he has b's and z's available.
Old Jan 4, 2005 | 04:16 AM
jdmsi1320's Avatar
The B20 block and B18 block are pretty much the same except the b20 has a bore of 84mm and b18 has 81mm
Old Jan 4, 2005 | 08:42 AM
The Specialist's Avatar
B20 has bigger displacement and plus it's more tourquey then the B18
Happyfeat2006
Mar 6, 2009 02:21 PM
ApexOne
Oct 3, 2004 04:05 PM
LsBack
Aug 8, 2004 04:23 PM
redsled00
Apr 10, 2003 10:09 PM
CheezeFrog
Sep 24, 2002 04:46 AM
