OBD0 to OBD1 conversion
Old Jan 6, 2005 | 07:06 AM
TeaminlineB16's Avatar
Default OBD0 to OBD1 conversion
I have a B16 (JDM and OBD0) and how do i convert it to OBD1? From what i have come to learn, i need a distributor swap and cut and and adapt plugs to wire harness, get OBD1 injectors with plugs and attach to harness, and an OBD0-OBD1 conversion harness.....is there something missing? I want the ref. to be happy so my *** doesnt get in trouble....plus i got a fix it ticket....HA!
Old Jan 6, 2005 | 09:32 AM
smart monkey's Avatar
Default Re: OBD0 to OBD1 conversion (TeaminlineB16)
this is what you need.
OBD1 dohc vtec dist
obd0-1 jumper
you can also get a dist jumper from locash racing
get a 4 wire O2
a OBD1 ecu or you can rent a P30 from me for ref testing
also if you want to ref it change out intake man and Tbody to OBD1 B16a intake man. also you should get a stock or dc header for a 94-delsol dohc vtec or 99-si with the O2 bung near the cat, you need this for ref visual.
you do not need to get OBD1 injectors or get rid of resistor box.
4DRmafia
25
Oct 12, 2011 03:01 PM
90civicstdgold
Jul 7, 2011 03:20 PM
gocivicgo
Aug 7, 2003 08:05 AM
EFing8
11
Dec 15, 2002 09:08 AM
h46it
Jun 18, 2002 05:23 PM
