ECU Code 2 ??? PR3 ecu
Old Jan 9, 2005 | 04:13 PM
OldSchoolSwap's Avatar
Default ECU Code 2 ??? PR3 ecu
I have a PR3 ecu preOBD on a B16.
I am now getting a code 2.
Checked the PR3 troubleshooting chart but no code 2 exists. What could be triggering this "unknown" code?
Old Jan 9, 2005 | 06:44 PM
Turbogixxer's Avatar
Default Re: ECU Code 2 ??? PR3 ecu (OldSchoolSwap)
You are probably reading it wrong
Old Jan 10, 2005 | 02:22 AM
tinkerbell's Avatar
Default Re: ECU Code 2 ??? PR3 ecu (turbogixxer)
code 20 = ELD = electrical load detector???
might mean your alternator wiring is messed up or similar...
Old Jan 10, 2005 | 11:13 AM
primeredbeast's Avatar
code 1 and code 2 i belive are the primary and secondary o2's do you have 2 o2 sensors hooked up???
Old Jan 14, 2005 | 08:14 AM
Default Re: ECU Code 2 ??? PR3 ecu (primeredbeast)
No, only one is hooked up and jumped to both ecu pins. Its been running just fine for almost two years. Till now that i just installed the VAFC.
It blinks twice fast and then pauses. Then blinks twice again and then pauses. They are short blinks, not long.
Old Jan 14, 2005 | 08:18 AM
It is also running lean according to the rich/lean gauge. Even at full throttle, only the first RED LED turns on my R/L gauge.
It richens up only at idle when ever it wants but goes back to lean when driving.
Old Jan 14, 2005 | 09:05 AM
EP3_05's Avatar
Code 2 is the secondary O2 sensor. I would either wire them correctly or convert to OBD1 and run one O2 sensor or have your PR3 chipped to run one sensor. The PR3 needs inputs from both pairs of cylinders to run "correctly".
Old Jan 14, 2005 | 12:43 PM
Default Re: ECU Code 2 ??? PR3 ecu (91civic)
what you said makes perfect sence, however. why did this code just come up after installing the VAFC? (remember, iv'e been running the motor for two years with my current setup, no ecu codes ever popped up)
Could it be due to the the engine running extremely lean the O2 picks up the new engine condition then sends out the code. Possibly the computer's way of saying "hey i'm leaning out".
Remeber it tries to adjust the mixture while at idle and achives a richer mixture but after driving a few minutes it leans out and the code pops up eventually.
Next step is the dyno in a week or two, but i don't want to drive the car like this....
Old Jan 14, 2005 | 12:54 PM
Katman's Avatar
have you tried resetting the ecu after your VAFC installation?
I'm betting your gettting this odd code because of something not setup or wired in correctly with the VAFC...
Old Jan 14, 2005 | 12:57 PM
Default Re: ECU Code 2 ??? PR3 ecu (K@man)
Yes i did, i also double checked the wiring according to the install sheet and everything is correct. The VAFCII also operates just fine and picks up all the sensors, rpm and psi.
Old Jan 14, 2005 | 12:59 PM
Katman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OldSchoolSwap &raquo;</TD></TR><TR><TD CLASS="quote">Yes i did, i also double checked the wiring according to the install sheet and everything is correct. The VAFCII also operates just fine and picks up all the sensors, rpm and psi. </TD></TR></TABLE>
its a VAFC 2 eh? haven't toyed with one of those yet.
Perhaps ver.2 is 'smarter' than the ver.1 and it's lookin for the 2nd 02 sensor. Maybe wire in the 2nd 02 like it should be and see what happens, yea? or convert to OBD1
Old Jan 15, 2005 | 08:32 AM
try to wire the second 02 up
Old Jan 15, 2005 | 11:21 AM
cherroneballs's Avatar
try to adjust your settings on vafc and then reset your ecu I ahd codes at first when I installed a afc and then just played with it and got the codes off.
Old Jan 21, 2005 | 03:41 PM
Default Re: (cherroneballs)
The VAFC is to complex and i have no idea how to tune it. I did all the install myself but adjusting all the settings is a diffrent story all together.
I'll talk to the dyno shop and see what they say about this.
Any other opinions are appriciated. thanks!
nitewolf
Jan 20, 2009 02:19 PM
MelloYelloCRX
Jul 22, 2006 05:17 PM
crxtreme27
Feb 4, 2004 10:19 PM
hondacivic4g
Mar 2, 2002 08:16 AM
