Lsvtec ecu and harness
Old Dec 21, 2004 | 01:29 PM
LSVTEC_ALLMOTOR's Avatar
Default Lsvtec ecu and harness
Hey soon I will have an 1998 itr shell or 1998 rs, but im really confused with putitng all thease OBDI together, first what vtec ecu will I use?Any?What OBDI will I need for dizzy?Will I need a OBDII to OBDI adapter harness ?
Old Dec 21, 2004 | 03:24 PM
smart monkey's Avatar
Default Re: Lsvtec ecu and harness (Lsvtec2.1liters)
to make it easy I would get a 98-ls or gsr or R engine harness. cause it is OBD2 and will match a OBD2 motor and chassis harness. then get a OBD2 to OBD1 jumper and then get a obd 1 ecu. if you go hondata just use a P28 since you are going lsvtec. you could also use the hondata P28 that they sell so need for a jumper. it has the OBD2 plugs on it.
Old Dec 21, 2004 | 04:24 PM
Default Re: Lsvtec ecu and harness (smart monkey)
Thank you so much would I use an obd2 or obd1 for distributor?Im using an b16 head.
Old Dec 21, 2004 | 04:45 PM
if you use the OBD2 engine harness it would be easier to use a OBD2 dist as the plugs would match up.
Old Dec 21, 2004 | 04:49 PM
haha owned I forogt, thanks so much man later
mindless4banger
Jan 21, 2016 09:33 PM
jdmshawn95
Jan 14, 2011 11:12 AM
CivicB18C1
Jun 13, 2008 05:47 PM
EG*5*CIVIC
Apr 28, 2008 02:04 PM
filipedua
Jun 13, 2006 08:32 AM
